Ok, I'm pretty stumped. I have an 01 S with stock fogs. I wanted to have the fogs come on at my request so I pulled the relay and ran a wire from it to a constant power wire. We'll now they don't work. I've got no power at the fog plug in at the bumper. I DO have power at the relay and I DO have power at the 15a fuse in the cab. I pulled the switch off the column and I DO have power there. When I touched my voltage tester to the fog wire on the harness it lit up and the fogs came on. I can't find a diagram to take apart the switch but I know there should be a ground that completes when you turn the fog switch. Any ideas to help me fix this problem? Thanks.
