2011 Corolla S - Rim Question
I am planning on throwing some. Xxrs 522 on my 2011 corolla s the rim configuration is 18x8.5 +37 my question is will i have any issue since im on tein lowering springs?
Thanks toyota fam :thumbsup:
The proper tire size is the 225/40R18 and should work okay with that set up. I have a friend that is running 17x8.25 +28 just fine and that sticks out 7mm wider then your setup. Yours is only 1mm different then mine at 17x8 +32. The other thing to look at is that your wheels are wider with the same 225 width tire so the tire will stretch a little more giving you a little more clearance.
