both Charging port stopped working
Hello,
It looks like both of my charging port stopped working.
First it was the one inside the hand rest then after few days it was one under the radio. I did put a two in one adapter in it. Not sure if it burnt the fuse or something.
Any idea? I had the extended warranty. I will go let them check it but they said if its not covered by the warranty. They will charge $150 for inspection. LMAO!
I replace the fuses. locate your hood and the fuse box pop it open read the panel you have spare fuses, best to put in like 4 like with the lil white fuse puller. other is located in car under lower left dash..
