Corolla ECU
So I have been doing some research and I found a supercharger kit that comes with a reflashed ECU. Does anyone know if a Corolla has the same ECU as a 2009-2011 Lotus Elise?
I highly doubt it, since that's a slightly different model engine. They used the 2ZZ-GE in the Lotus, not the 2ZR-FE that they Corolla uses. Not sure what the exact differences are though between the 2 engines. I just know that you need a low compression ratio to run a supercharger.
