HELP: 2006 Corrola le DRL disable
I recently bought an hid kit and read you had to disable the drls. I cut the yellow wire and grounded it . After I did that, they shut off and I could manually power them on and off but 10 seconds later they came on? What do I do?
If you haven't figured this out already look up the color of the wire. It's in a harness near the steering wheel under the dash. Snip the wire and tape it off that way you can re connect it.
