B barnburner New Member Sep 7, 2014 #1 Sep 7, 2014 #1 I installed LED's for turn signal with a LED flasher and the back lights work great. When I installed the front turn signal LED's it blew the 10 amp fuse?? Any suggestions why or remedy?
Donabed Kopoian 6 Speed Master Sep 7, 2014 #2 Sep 7, 2014 #2 Sounds like you got the wrong bulb. There is 7443, and 7443 CLK, and it sounds like you were accidentally sent or accidentally ordered a 7443 CLK.
Donabed Kopoian 6 Speed Master Sep 7, 2014 #3 Sep 7, 2014 #3 Either that, or the unit itself is shorting from using too much solder.
