Take it apart to confirm it's a sticking caliper. It maybe if it's the OEM original. It could also be due to lack of grease on the brake slide pins or corrosion on the metal slides. This will cause the symptoms you described. Calipers are either rebuilt or replaced. For a DIY person, it's the latter. Slide pins should be re-lubed every few years as part of the brake inspection/PM.
