My brakes were fading, pedal going right to the floor.
Fine. Had a friend install an aftermarket master cylinder. Problem solved.
BUT... the brakes for all wheels except the front driver side would "lock up" somewhat and get hot while driving.
Slightly cracking open one of the lines coming off the master cyl would relieve the pressure for a while. After 30 minutes more driving, another mini-bleed would be required.
Checked the adjustment at the top of the pedal.
Replaced the aftermarket master cyl with a used one from a car with 80,000 km. NOW ONLY THE FRONT LEFT WHEEL LOCKS UP AND GETS HOT. Mini-bleeding it's line (the "front" one) helps for 30 minutes.
It is the weirdest thing I've ever seen.
Any suggestions?
My "backyard mechanic" brother says he is stumped.
Any suggestions?
