I recently pulled the motor out of my 2001 corolla to replace the clutch, once I got the motor back in I hood everything up. And now the car will only start for a half second or so then shut right off, I can pump the gas pedal and it will run very rough. It will not idle at all and only runs normal if I floor it. The scanner read OBD o2 sensor incomplete along with the catalyst incomplete. I don't know what to do from here. I've checked vacuum lines and all were hooked up and all sensor I could find are in the right place. HELP
