I have a 2004 Corolla with 145,000 + miles. The lifters started clanking about 20,000 miles ago when it was cold. It is fine when It warms up and the engine is strong (good compression and power). I have changed the oil every 3-4,000 miles religiously.
Where do I start?
Do I pull the oil pan and clean it and the pick up?
Does it need a new oil pump?
Is there a seal on the top of the motor that is letting the oil leak back down? Is so is it easy to fix?
Is it worth it to start this project? The car will need cv boots, water pump, alternator soon I'd guess? What is the life span of these items or what other parts fail typically and when?
Any help is greatly appreciated.
Thank you.
Where do I start?
Thank you.
