2006 Corolla LE - MPG Decrease
Hello,
I have a 2006 toyota corolla with almost 130k miles on it
over the last 6 months I have noticed a slow decrease in my mpg numbers and now I am getting between 25-26 mpg
prior to 6 months ago I have never gotten below 30mpg ever!
any suggestions on where to start looking for reasons that my mpg is plummeting?
O2 sensor: wouldn't the check engine light come on? (I.e. It doesn't come on)
Fuel mileage measurement: I fill up my car every time at the pump and then reset my trip "A" until the next time I refill the tank
Autozone: I was unaware that they provided free scans, I'll try to stop by there today
"O2 sensor: wouldn't the check engine light come on?", I'm not absolutely sure.
But with lower mpg and over 100K miles, Me? I would at least clean them. Also I would clean the throttle body/intake and put new plugs along with a synthetic oil and filter change.
I would run a scan though first to see if that comes up with anything related to a drop in mpg.
I shop around for Best Price on Good Guaranteed easily exchanged parts and do Most servicing myself. Example: if I replaced 02 sensors and that didn't remedy the problem my Autozone would take them back *if* I wanted to do so.
Good Luck!
That's the way most people try to calculate fuel economy, but unfortunately it's not an accurate, as it allows all manner of uncontrolled variables to affect the miles per gallon calculations.
Good Luck!
What autozone do you go to??? No other parts store lets you do that. And I'm sure that autozone isnt supposed to either.
Why not just diagnose an issue rather than parts swap? You know that you can test your o2 sensors...
I replace my upstream HO2S every 60k for optimum fuel economy. You might be due. I changed mine on my '08 Matrix and saw a 2-3 mpg increase (if yours is more worn, that number will be larger).
They won't throw a code until they are way out of parameter or completely fail. Best off getting it replaced.
Don't do the downstream, just the upstream. For the downstream, I only replace that one when I get a code for it.
