2009 Corolla - Rumbles Loud
My 2009 auto with only 47000 on it rumbles loud when accelerating thru a right hand turn only.Not left and not going straight.When i slightly let off gas rumble goes away .jack rabbit starts on straightaways does not produce sound or left turns either.
I am guessing CV joint or Ball Joint.Any help would be appreciated.
First things first, check the torque on the axle nut for both CV Joints. My friend recently replaced a CV joint and had a rumble that turned out to be not using a torque wrench on the axle nuts.
If that checks out, then it may be a CV joint.
Your muffler is rattling from a loose connection near the front of your car. Simply grab the exhaust tip of the muffler next time you hear it. If it goes away get your muffler connections looked at. Cheap fix.
