2013 Corolla S
I was so excited to learn that toyota had finally put navigation in the corrolla. In my 2007 corrolla I had it installed.
Problem is the directions are horrible! My smartphone is accurate, why not my corrolla? Even the one that I had installed on my 2007 was accurate, please help, as I like to travel.
The nav in my 2014 is just as good as Google Maps. Maybe you need a map or software update?
Soumikcha, I use the navigation in my 2014 S for a couple reasons.
1) Voice Activation (it's not half bad but sometimes you gotta repeat yourself).
2) I don't have to look down at my phone to type anything in.
3) No need for a windshield mount.
And it also works if cell signal is lost.
the reason your navigation is not accurate is because it may be a year behind even though is a 13 model the nav disc was a 12 so you have to update it every year and its always a yr behind so the latest will be a 2013 call your local dealer here in tx it cost about $169 if its the disc style update if its newer may be more
