Can I Remove The 2015 Radio Without Problems?
koby
I cant seem to find a solid answer on this but since the corollas have engine immobilizing systems im leery of removing the radio to install a line out converter and remote wire for my amp. Has anyone removed it before and disconnected everything without problems or should I steer clear and shoot for a different way to install my amp?
I had a code on a radio, as long I had that password, I had no troubles entering it to work afterwards, was not atoyota was Honda
I haven't had a code pop up on my Entune, or any other Toyota radios. I also see nothing in the manual for it. You should be fine.
Radio codes won't prevent the car from starting either ... otherwise a stolen radio would leave you stranded.
