Help Radio Issue
upgrading radio in my 2011 corolla, install went great until about 5min when new radio stopped working,\. Checked all fuses and made sure power was at radio. still nothing....finally put stock radio back in and ....this now does not work
What am I missing.....Please help
called my dealer they did not help:(:(:(:(:(
ohms meter to test out the line. Possibly you got the wrong fuse?
If you are positive about doing this, I get a wire place to a 12vdc source, and see if the radio works on that. if it does, then you know you got a short on your harness or fuse? that is a start.
Some radios needs two 12vdc to work. one on a ignition, the other on the bat, one is a memory and the other is power. careful some also have a blue that is for a antennae pwr one.
Welcome aboard.
