Idle Problems
I have on my 2010 corolla with idle problems. I use only high octane fuel because of engine bolt ons. When the car is on idle when at a stop light it seems to vibrate hard and engine sounds like it is going to die. A very slow bush cutter like sound. The car has died on its own a few times. I would give it to the dealership but I have a unichip on the ecu and check engine lights that always pop on. I changed the oil and the sparkplugs but I am not too sure if the spark burnt out from running it too hard.has anyone had this issue? Or have an educated guess to what it might be?
Without proper diagnosis time we can only guess. With that said I would be checking the mass air flow sensor and the throttle solenoid and throttle pedal position sensor.
