Mirror Embedded Signals
Muthco.com LED mirrors used to make for a number of cars.
you will need to work the wiring into the car, locate the harnesses inside under the dash, if that is to complicated, just tap off the turn signal wires themselves. going through the firewall.
WIth the Muth system you have to if remembered correctly get into the weather stripping
Sticking something on the outside, to me is tacky. I rather have them in the light. the heated side mirrors will add up the cost, why I guess this is the alternative route
Junction box. You have to remove some of the trim to get to it. It is located near the interior fuse box.
If you subscribe for $15 to the TIS website, you can get the manual for the 2013 Corolla and screenshot what you need for when you are ready to work on it.
due to acid rain, mud dirt etc, you must use 100% alcohol, only 91 plus can be found, and you have to get a clean contact surface. Most likely the backing is not 3m, and you can get your own 3m double tape.
good luck
