Tire Sensor
Hi,I'm a new owner of a 2013 corolla, I love car so far but what's up with tire
Sensor checked tires twice all at 32 psi like they should be, light will not go off.
Turn the ignition on (do not start car). Look at your OBD-II port and start looking right toward center console. Should be able to see a button that has the low tire warning symbol. Press and hold that button until the light on the dashboard blinks three times, then release. Wait a couple minutes, and the light should shut off after calibration completes.
added note. do not ignore the sensor, it will tell you as well, if you lost air and getting flat.
Also the sensors have batterries in them, each, if they go you be replacing them.
Reset I simple. like said find the center and feel for it....
