White stains on tail light?
Discussion in '2014 + Toyota Corolla' started by Dapsters, Sep 5, 2018.
  1. Dapsters
    Dapsters New Member
  2. Corolla Forum Sign Up!
  3. Rock'n Roller
    Rock'n Roller New Member
    Hard to tell from the photo, but it looks like the surface was burned with a buffing wheel. If not, it could be the UV coating starting to peel. You may want to try and use a product designed to polish poly-carbonate headlights.
  4. JohnnieXSE
    JohnnieXSE New Member
    You need to post a clearer photo. I'm guessing the white stains are calcium deposits. You can Google different methods to remove it. Most methods call for vinegar and some baking soda or lemon mixture. I'd try it in a small area first to make sure it works.
  5. OP
    Dapsters
    Dapsters New Member
    I didn't realize how bad that picture was. The clear part looks like it has cracks, I guess it's just in the uv protective layer.
    https://i.imgur.com/zVYWWaU.jpg
    I might need a new tail light, ebay has them for about 50,but I don't want aftermarket parts and IDK where to get genuine at a good price
  6. JohnnieXSE
    Once you have the OEM part number, you can simply plug it in under Google shopping and find the cheapest price.
  7. Timmmm
    Timmmm New Member
    That looks like it might be car wax or detailer residue. When you say it won't wipe off, did you try a microfiber cloth? It doesn't look that bad, though.
  8. OP
    Dapsters
    Dapsters New Member
    Yeah I used a microfiber and some glass cleaner and washer fluid it doesn't budge
  9. OP
    Dapsters
    Dapsters New Member
    Now theres a stain on my front passenger headlight, vinegar didn't work
  10. tangocharlie
    tangocharlie New Member
    Have you tried something a bit more abrasive - like Meguiars Ultimate Compound? I know some folks say don't polish/wax your lights but I do and have had no issues. Just take it easy.
    I used Ultimate Compound on by badly clouded Tundra lights and they looked new and, stayed that way for a long long time.
  11. OP
    Dapsters
    Dapsters New Member
    No I'm worried about scratching up. The headlight/tail light and making it worse. I do have some rubbing compound though I think by turtlewax
Share This Page
