W wehavetogoback New Member Jul 1, 2014 #1 Jul 1, 2014 #1 Not my car...just using as an example. It's the trim that goes along the top of the frame. Mine is heat damaged - it's peeling off because the heat from the sun has shrunk the material. Any easy fix to this?
Donabed Kopoian 6 Speed Master Jul 2, 2014 #2 Jul 2, 2014 #2 Hard to tell if that is the weatherstrip or part of the panel. Check car-part.com to see if you can get a hold of a replacement that is in good shape.
Scott O'Kashan Super Moderator Aug 8, 2014 #3 Aug 8, 2014 #3 Welcome to the Corolla Forum! :thumbup::clap::thumbup1: You can try automotive junkyards to find a good used part. Any updates?
