Uh, thanks for the advice but again, it wasn't me who burnt an engine up, it was a close friend of mine. If I'd done it I'd admit it
I'm actually pretty good about watching the gauges in my cars and trucks. On my Silverado I've even added extra gauges to monitor things a bit closer since I do a lot of towing with that truck.
I'm not sure that I agree with your statement about fans not being effective at speed. While I agree that a fan's primary purpose is to keep air moving across the radiator when stopped or at slow speeds on my Silverado I've added an auxuilary trans cooler with an electric fan mounted on top of it. I've seen that auxiliary fan work to keep the transmission oil at steady temp whereas without the fan my trans temps tend to drift around a lot more.
I've found that the stock gauges on most cars leave a lot to be desired. I've never seen the water temp gauge move away from normal on my Corolla, even using my Scan Gauge II on doesn't show much; the water temp stays pretty steady pretty much regardless of what sort of driving I'm doing, though to be fair I've not done any towing or four-wheeling with my 'Rolla :laughing:
Kevin
