Where Is A/C Clutch Relay
Everything works but the A/C blows hot air?
Turn on the A/C and see if the clutch cycles before doing anything. The relay should be in the engine compartment fuse box.
A/C Relay
Yes, the fan just blows hot air. The system has pressure and has freon. I suspect relay is bad but can't find it. Can someone specifically tell me where to find it? the box is under the hood. Does not have anything that reads A/C relay.
The A/C clutch relay is in the fuse box next to your battery. It's actually labeled as "MG CLT" on the diagram found on the cover of the fuse box.
I'm having the same problem, all fuses are in working order. I've heard that this compressor doesn't have a clutch, but rather a solenoid. Is this true, and can this be the problem?
2009 corolla did anyone find the location of the relay? under the hood in fuse panel / labeled as "MG CLT" on the diagram found on the cover of the fuse box. that spot is empty.
Lui
I search the problem. Sounds like is the relay. Next to the battery. There are a few videos on YouTube about it. Sound like a common problem from 2000-2013
#22
P
Please can you take a picture of this relay in the fuse box and share to the forum to show its exact location in the fuse box. This will really help to understand.
#23
Like everyone else im looking for the ac compressor relay on my 2012 toyota corolla. The relays and fuses show nothing for the suggestions above. The owners manual is different from the fuse panel locations all together. Anyone know exactly where this bandit is. Thank you.
